So today's efforts. Started off by clearancing the block back for the oil line as I mentioned above. No picture but it's nice and smooth now. All good and snug.
I think I have found an adapter to let me put the oil pressure senders up on the turbo ala banks. 4 AN adapter with double holes tapped 1/8 npt. For the price we will see if it solves the problem. Think I'm going to put a similar dodad in the Schrader valve port for a fuel pressure gauge.
I've been fine tuning the glow plug harness. Turns out if you have a tight spot you can open up the T's and move things around a bit. I may fuss with it a bit more. One draw back to this style harness is that it would be a ****** to install with the lines in place.
I started working on the plumbing. To do that I figured I'd better set the pump in place so I don't screw up and put something where it shouldn't be.
Here's the filter head. I bailed on the valves for now. I just couldn't figure out how to get them in there cleanly. I may pick up a couple swagelok compression valves and see if I can get them in the lines. The heater core lines run out the top. The water will come from the block and into the left side via hose. If you look close, there are hoses behind the alternator. 1 will be the water return from the turbo the other will be the return to the water pump. They tuck pretty nicely up there. All in all, the manifold worked out okay, but not quite as slick as I though. I need to pull it now that I know where things are going and adjust the depth of the tapped holes. Have to love that no two npt's are exactly the same from brand to brand. [emoji21]
I reclocked the turbo so that everybody is pointed in the right direction now. I should also have the desired 20 degree angle for the water ports. Need to get the up pipe on and mounted which means getting the adapter plate back on. Now that I think I have an oil pressure solution, I am not real worried about getting to that rear plug.
Here's what it looks like with the pump quasi installed.
I like the red line clamps. It's a nice touch. I adjusted them and swapped out the bolts for shorter ones so they don't interfere with things now. You can kinda see it here but I made my first AN fuel line. Here's the back side.
I think it will clear everybody. It was the first one I've ever made. Went together pretty well I think. Hopefully it don't leak.
I primed and painted the high idle solenoid. It's still drying.
I haven't really messed with the pump and lines before. It's not going to be pleasant to get those bottom fittings tight. I may have to make one of them there fancy sockets. I think I'll wait to put the injectors and return lines on until I get it in the frame. I may pull the pump back off before I set it in frame.
Starting to come together.
