Busy day. I'm beat.
So first up, thermostat housing. Needed something to keep the ball in there. Stainless star washer.
Motorcraft thermostat.
And some ultra black on the gasket surfaces and we got her licked.
Next up. I left the manifolds half done last night. I swapped out my blast gun. So much better. Compressor actually will almost cycle off and on now. It will cycle if you pause for a minute to shuffle stuff around. No more balls out all the time. Way more efficient.
I didn't take a lot of pictures during the process but I think it's gonna be good.
I prepped the other manifold for the pyro. Flattened a little spot and drilled and tapped for 1/4 npt.
And the other side.
And with the oil cooler installed.
The turbo mount brackets are smoothed out and done.
Some of the accessory parts.
Here are the washers for the exhaust manifold. I put them on the titanium wire and twisted it so they couldn't get loose. Then I blasted them on it and then plated 8 at a time first batch.
And on the bolts.
You can see what they looked like before sitting in the background.
And installed loosely.
The banks up pipe is in the blast cabinet. It's about half done. I had a vacuum cleaner malfunction that led me to go ahead and do a full service on the cabinet so that's where I got to.
More of the same tomorrow.
