Well, it's been an up and down day. Mostly down and frustrating.
Block heater is a fail.
It's not the right type of back. I think I can make it work but I'm not sure I want to. The problem with this particular one is really that the bolt in the middle is too short. I think swapping it out for a longer one would probably solve the problem. I'll see how easily I can get my hands on the correct one. May not be worth screwing with.
Meanwhile I started working more on the accessories.
Clip was blasted and plated. Bolt and clip were blasted and treated with black oxide.
Then I did the alternator bracket and installed it. I also stuck the coolant filter bit on there.
So, I have a little bit of a clearance issue with the alternator and my manifold. I think I can make it work but the valves I bought I think are going to be useless. So I have a couple options. I can do without valves or I can get inline valves. I need to revisit the plumbing path too. I may change things up and plumb the block connections in AN. Not a big deal now that all those lines will be feeding will be the heater core and the coolant filter. Again, need to sleep on it.
I started wiring a little. Here's the factory coolant sensor.
I fished the wire through the gp harness and added a tail of loom to the last connector. It's actually just a T connector.
I installed the oil feed for the turbo.
Had to touch the lip on the casting.
Little touch up of course.
Fitting installed.
Line installed.
I may actually pull the line and grind the block casting back a hair more. The points of the hose fitting just touch the block as it goes in. I would have liked to snugged it up a touch more but I didn't want to break the fitting.
So that brings me to my next big problem. Oil pressure sensors.
So I can kinda sorta get to this spot but I can't really get a sender in there. I could put an extension tube in there but that makes me a little nervous. So I either have to do something up at the turbo or I may be able to do something with the stock port up on top. Since I'm not using the banks turbo I may have enough room to do something there.
I finished off the lines and clamps on the IP.
Turned out pretty good. I'm not real happy with #2 injector line but I'm not inclined to mess with it right now. I ended up reusing the 4 line clamp. The set of new clamps I bought only had clamps for 3 lines.
So tomorrow I'd like to get the power steering pump brackets and AC brackets. Need to do the hold downs for the valve covers. Turns out I've got a nice non-cork set of valve cover gaskets. I picked them up on clearance from rock auto. [emoji2]
So it doesn't seem like much but I was busy all damn day.
