U can leave carrier in truck if 2 pinion. Spider not sure if same with 3...just pull cross shaft an spider gears and side remove opposite side axle first pass through broken side...reassemble in reverse order.
Everything internal to the diff looks clean and well oiled, only the passenger axle tube has shown signs of water, and the hub (outside surface at least) looked oiled as well. Very weird that the only portion showing rust like that was in the axle tube itself. I was going to push bailing wire through to the diff from the passenger side and drag rags back through several times until I stop seeing chunks, then thoroughly go over everything in the differential housing to make sure nothing had snuck in.Judging from the pics, I'd say that axle had a fair amount of water in it for some time.
Is there a way to safely remove rust from the ring gear? Or just run it and not worry about it?
If only...riotwarrior said:Probably good idea clean out tubes and carrier real good....round toilet brush through tubes? Find one threads on broom handle then u can work at cleaning **** on a stick from afar
Was it used to back a boat into water....hot axle cooled can draw water in vent tube maybe if deep nuff
Or bad seals ....
If you need a 4.10 DRW REAR DIFF, I have one. 250$
