Left axle is broken. Easy fix.
that would be a first.Left axle is broken. Easy fix.
Yikes. I could see really bad bearings causing that to fatigue. Geeze. It's tough enough to get that axle in there when you can get ahold of it. The axle shaft is junk. Can you push it out and cut a few inches off with a cutoff wheel to give you room to work on it? The axle will be fairly tough but I would think a cutoff wheel on a grinder would make pretty quick work of it.
Good luck. I'll be checking my hubs frequently.
riotwarrior said:If you gut the carrier there is no reason not to pass axle through imho...
Just use the axle as its own slide hammer? Lol
No clips or anything retaining the axle after removing the 8 bolts through the flange at the hub, splines 'float' in the spiders. Can't put a rod through the diff from the passenger side without pulling the spider-holder rod/pin for the non-axle-spiders at which point the axle-spiders don't have any reason to stay put; likely easier to just pull the diff with the 4 bolts at the bearing caps and then roughly proceed as you described since access to those bolts is a lot easier than the tight working space otherwise. I'll likely pass the broken section through the entire axle and out the passenger side though without resistance rather than beat the splines past the burr with 8' of steel rod I don't have yet.I'm not familiar with these axles but arent they just splined with no c clips or anything? Can't you just remove the axle from the other side and slide a bar/rod through the diff and hammer it out? I think the spiders will stay in place?
Axle bolts to the hub at the flange you see at the end when the hubcaps/covers are off your wheels, but otherwise the hubs don't hold the axle in place. This thing is getting caught in the axle tube itself on a burr that protrudes into the cavity enough to bind on the splines.jhenegh said:Couldn't you just take the hub off? Or am I totally missing something? Take the ratcheting nut off and pull the whole thing off, then slide what's left of the axle out
