Oelmensch
10.25 complete axle replacement SPOILER (Broken Axle)
Truck got hungry last night and apparently ate the rear end (Whoo! 54 miles into ownership ); yoke spins freely while the tires could care less. To my knowledge it is/was a 1st-gen 10.25 4.10 open diff that came with the truck in my signature. I'll pull the rear cover to see what ultimately failed, but I don't have high hopes for it not being terminal for this unit.
I found a complete drum-to-drum rear axle assembly off a 1988 4x4 dually which was in an airport truck that had 3500 (not a typo) miles on it and is an upgrade to a limited slip differential for nearly junkyard price. I've read/been-told that I'm better off swapping in a known good axle rather than going through the joy of doing a complete R&P setup (which I haven't done previously, but am reasonably capable) and there were annual servicing records for the truck since new (airports like reliability with their ground equipment too I guess) so this would be a pretty handy upgrade since I'd planned on doing seals/bearings in my existing unit later this summer anyways.
Three questions:
Thank you for any/all advice/help; I'll take plenty of pictures if there isn't already a reference and post them here as I go.
Three questions:
- Is there any reason that (rear) axle shouldn't be a bolt-in affair? From what I've read the only difference between the two is the new one would be a LSD, which really only changes the fluids procedure. Both should be full-float assemblies, etc.
- Any pitfalls in the swap/exchange to be mindful of? I'd assumed the yoke on my current unit is shot and might need the drive-line re-balanced with the new one, anything else?
- Do we have a good swap guide/article on the forums to reference? I'd dug around a bit, but 45 pages of returns with most being related to going from one rear end to another got tedious quick, but my search-fu might have been weak.
