Stomper4x4
Rotational play? Yes that is bad.
Yeah not ideal buddy haha. Thanks for the help, much appreciated!
Sure. The numbers are FC65662 for the pilot bearing and 614062 for the throw out bearing. Rock Auto has the pilot in stock, but not the throw out bearing. Od course that could chanfe tomorrow.Also @IDIBRONCO would you happen to have the part numbers for the timkin bearings?
Yes they are direct replacements.Or at least they are direct replacement for what I have in there, no alternate part with the clutch style change?
Yes. That's it with the correct part number. The last one I bought was from Amazon for right about $200. That was about three years back. I'm sure that it didn't come with the Timken bearings and plan to buy them before I install it.And this is the setup I need yes? https://www.rockauto.com/en/moreinfo.php?pk=4698030&cc=0&pt=1993&jsn=3
Perfect thanks again. Super appreciated!!Sure. The numbers are FC65662 for the pilot bearing and 614062 for the throw out bearing. Rock Auto has the pilot in stock, but not the throw out bearing. Od course that could chanfe tomorrow.
I'm certainly no expert on this but I thought a repair sleeve was considered a standard part of replacing the rear main seal due to the old seal wearing a slight groove. I know mine leaked a bit without the repair sleeve.
If you wanted to be cheap about it for now, you could do a few tack welds to secure the two halves of the dmf together. Come across that a few times
This is definitely true, especially if the temporary fix works well.Or temporary fixes can become permanent ones
This is definitely true, especially if the temporary fix works.
The welds you do through the access hole on the bottom, and then plan on doing clutch later was the idea. Or temporary fixes can become permanent ones.
I didn’t touch my rear main when I swapped flywheels, it wasn’t leaking so I left it alone. Plenty of people do it preventatively, but they are fiddly to install and you may end up with a leak when you didn’t have one before.
One other thing I would be prepared for is a buggered up input shaft on the ZF5 where the old pilot bearing chewed it up. You can buy repair kits with a repair sleeve and special bearing if this turns out to be the case.
The Toyotas of the 80s and 90s seem to be well made but I won't ever drive another Toyota after owning a 1st gen Tundra--what a piece of garbage from grille to tailgate. There were at least 5 points where water would pour in to the extent that even trying to quickly wash the vehicle resulted in massive amounts of water in the cab, and none of the fixes were going to be easy. Almost every 1st gen owner I've spoken to had water leaks somewhere in the cab--no acceptable excuse for that failure from Toyota. Water would get behind the glovebox and reach some computer component where I would then find the fuel pump just running randomly--had to disconnect the battery cables when truck wasn't in use. You have to remove the exhaust or intake manifold to change the starter, tons of rattles and squeaks, less leg room in a king cab configuration than an '86 regular cab 'Yota with bench seat, and it's still not a full size truck despite what Toyota may claim. My '92 F250/F350 has ten times the build quality of a 2003 Tundra 4x4, but again, I do think the 80s and 90s small Toyotas were pretty well made for what they are.Agreed, but mine leaks so, it needs to be done.
I wish Ford had Toyota build quality. Just a new clutch becomes a whole pile of potential problems. My 92 Toyota is exponentially better made than the 89 Ford. But I need a big pickup and Ford is the best of those.
