I'm sure. Those things were HUGE!It does take up an awful lot of space in the shop,
On my old mans truck (1989 cclb) he is running Firestone Track forces, on my 1990 cclb I have primewells up front@Nero, just curious what kind of tires you're running without a steering shock. I switched to mudders and the vibration greatly increased. New shocks, newer front leafs, tight kingpin axle, tight trackbar, new poly bushings in front shackles but still lotsa vibes without that little single steering shock. I even checked hubs and wheel bearings twice just to be sure it wasn't them.
That sounds a lot like your brother gets to fix the bodyUpdate: swapped the rear axle with an axle I found on marketplace and it fixed the vibration. Finally. Now just to fix the body since my brother ran it through a fence
Interesting. Did you happen to look at the pinion for runout? Was pinion angle different after the swap?Update: swapped the rear axle with an axle I found on marketplace and it fixed the vibration. Finally. Now just to fix the body since my brother ran it through a fence
