In general, what part typically fails on the vacuum pumps? When I replaced the vac pump on my truck I'm pretty sure it was the original one, painted grey, with 300k and though weak it was still working/stopping things. I bought a Dorman about 8 years ago based on a member here saying the Dorman had the same casting marks as the Motorcraft units at that time and the pump has been solid since install. Is there any chance these premature failures are due to inadequate or wrong type of oil from factory? Worth removing factory fill and replacing it with something else?
And as a second thought, has anybody tried to add an electric vac pump to boost the overall vacuum? Could that cause a problem somehow?
