I don't know anything about the E4OD system but if the trans cooler is cold then sounds like no fluid running through it. Should be helping to keep that temp down, 190* certainly isn't crazy. What were ambient temps?
I don't remember, maybe 70-75
The test port is accurate.
Save your money on the big aluminum pan. They are more show then anything else. Now the saving from that fancy pan and put it into a better cooler.
I would ditch the current aux cooler and replace it with a cooler from a 6.0. That cooler with the radiator should cover your cooling needs.
That's what I'm starting to wonder.unless it's just not working as efficiently as a proper oil cooler?
I wonder if your condensor cooler just won't flow fluid through it fast enough? Maybe it's partially plugged? I don't think that the transmission should be getting that hot while you're running empty. If it still does after adding the second cooler, maybe you could try bypassing the condensor.
Going with a real transmission cooler as you are should help a lot.
It surprises me that turning OD off cools it down as much as it does.
Could that be partially blocked causing your restriction?I still need to swap out the spin on filter too. I was scared to try changing it last winter when i was in the desert, just in case the new filter I got was wrong etc. but in town there it's fine.
