Hi all,
I've been following the tank discussion. Love it!
But...... a new issue.
So I changed out the fuel selector valve (as above) and the truck has been running just fine, daily, for a week. On the front tank.
Early this morning I switched to the rear tank and drove, including on the freeway up to 60ish, for about forty-five minutes. I was experiencing a strange surging, most noticeable at speeds over 45. Almost like the cruise control was in charge (it wasn't on). This was after driving for fifteen minutes or so.
Later this morning I had some work to do locally and noticed an occasional surge while driving to the site. Still on the rear tank. Parked the truck for half an hour while I did what I needed to do and started the truck. Idled a little bit rough but not bad. But when I put it in reverse it was not happy at all, idling very poorly.
Turned it off and started again and all was well. I switched back to the front tank at this point.
Driving for 15 minutes I still got surging. It's mild, but noticeable. Got to an intersection (a big one....) and it was bucking for a while, thought it was going to die on me and block traffic, until it evened out. This happened as I slowed down to the red light, not so much when standing still.
I filled up the front tank and haven't had the problem since. (I've stayed on the front tank.) But, then again, I didn't have this issue with the front tank until I switched to the rear tank this morning....
So - a leak on the rear fuel tank part of the FSV, which had a lasting effect even when I switched to the front tank?
I recently replaced all the o-rings around injectors and put in new olives. Also put in a new fuel lift pump. The truck starts right up each time so I don't think air is getting in past the fuel pump.
All this happened after I used the rear tank (full) for a period of time for the first time. Worth noting that I don't often use the rear tank.
Any thoughts? I've looked elsewhere on this site but can't see anything relating specifically to the fuel selector valve (replacement).
Thanks as always.
