divemaster5734
The test drive was cut short when I got a really bad wobble at around 45-50.
I immediately assumed tires, so pulled them off and cleaned all the debris that had accumulated during the 13 years it sat.
Took it out and same.
I searched the forum and realized the driveshafts could cause this.
Since I went from e4od to zf5 I used the donor truck's front axle.
There's only one way it can mount.
I had the rear driveshaft made at a guy that was recommended by several transmission shops.
Going through some threads I realized there may be a certain orientation for the rear shaft?
It's a one piece, and the guy only needed a washer to balance, which I put at the 3rd member.
I didn't have the wobble before, but again, that was a long time ago.
The sway bar links are visibly rotted through, which I plan on replacing when I put in the '03 axles that are next on the agenda.
It's a new PS pump.
I didn't want to spend any money on the existing steering, as I'm saving and researching everything I'm going to need for the axle swaps, but was hoping to be able to drive it a little to shake the bugs out of everything else.
Am heading out there later today, and hoping for some inspection tips to diagnose.
Thanks
It's a new PS pump.
Thanks
