Willard3663
So I swapped my 96 extended cab long bed from an auto E4OD to a 5 speed ZF5. I have the Borg Warner 4407 transfer case that uses the flat flange face that the driveshaft bolts to with 4 bolts. I am trying to find both the front and rear driveshafts now, but here is my question. Are the rear driveshafts from the same build trucks, just older (so the 1356 transfer case) with the slip yolk style (transfer case end of the 2 piece shaft) the same length forward u-joint to carrier bearing? Basically could I use a driveshaft from a extended cab long bed truck that had the 1356 transfer case with the slip yolk, just take that slip yolk off at the u-joint and put the flange style yolk off my current shaft that's now too short on the longer shaft that I now need due to the ZF5 being shorter than the E4OD? I have searched the internet over and can not find the info I'm needing before I go digging through the salvage yards taking driveshafts out.
