300d experiences
m67tang
lawrenceburg IN
My 1983 300d turbo was purchased with about 80,000 miles. now it has 170,000 miles. Seems to me it has needed lots of work along the way. Because of the cost of parts I have had to defer a lot of the maintenance.
Since I got it this is a partial list of what's been done:
1 new injector
A/C complete overhaul- everything replaced!
all new fuses- it was arcing & blowing fuses daily
upper control arms
door check straps
tie rods
rebuilt vacuum pump
new glow plugs
Now here's what its needs next:
All new lower suspension
new steering gear box
new oil hoses from oil filter
turbo rebuilt
trunk seal
hood release cable and handle
body work & paint
driveline flex discs
driveline carrier bearing
fuel cap seal
side trim molding clips replaced
timing chain is about due
I know I am forgetting stuff that's been done or needs attention, but this seems like a long list to me. When I drove a toyota none of this stuff was an issue. The car had less parts? It seems the maintenance never ends. I read about people that drive 400,000 miles with out hardly any work. Maybe its perspective?
What is your experiences with these cars? I wonder if I should drop it and go back to a toyota?
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
To make a long story short, my experience with these cars has been that there are essentially three processes to owning one:
1) Find a car that's cherry to begin with, and keep up on maintenance as it's due. In this day and age, it's very difficult to find a W123 that's cherry, unfortunately.
2) Have a car that's in fair condition and address every issue that there is. In my experience, this is going to cost a lot of money...as someone once said, "there is nothing more expensive than a cheap Mercedes".
3) Have a car that's in fair condition, keep up on basic preventative maintenance, but don't worry about every last little thing. In my experience, this is the most economical way to run one of these cars...and, if you can live with things like the cruise control, climate control, etc. not working properly or at all, these cars can be very economical...
Going into it a bit further...let me go off your list one by one:
1 new injector - I'm a bit surprised that an injector needed to be replaced. These injectors are much more rebuildable than the Stanadyne injectors on our IDI's, and they don't fail nearly as often. I wonder if a Diesel Purge treatment could have cleaned it up?
A/C complete overhaul- everything replaced! - That must have been hideously expensive!! Unfortunately, the climate control on these cars is finicky and can get quite expensive when parts fail...that's why, when the system fails, so many people just leave it that way. For that reason, IMHO if the climate control is important to you, you're best off trying to find a car that's already had the work done.
all new fuses- it was arcing & blowing fuses daily - That one surprises me a bit, although I have found that ceramic fuses last longer than the plastic fuses that you typically find for these cars at the auto parts stores.
upper control arms - That one doesn't surprise me...the suspensions in these cars was designed more for comfort than for longevity, and in fact I condemned all three of my M-B's on large part due to front suspensions that were in desperate need of rebuilding. More on that below.
door check straps - I'm guessing that these weren't greased regularly. While I would agree that the design leaves much to be desired, I've found that, if you grease them up regularly, they'll last longer...but, most people don't think to look at them.
tie rods - See my comment on the control arms and below.
rebuilt vacuum pump - That one makes sense...
new glow plugs - IMHO that's routine maintenance on any diesel.
All new lower suspension - Like I mentioned above, the suspensions on these cars were made for comfort more than longevity, and IMHO is the true Achilles' Heel of these cars. How quickly does the suspension eat front tires? I had a '79 300SD that would eat a brand-new tire in about a thousand miles :shocked: IMHO I would look at how quickly the tires get eaten as a gauge of how badly the suspension needs to be re-done...basically, are you willing to throw as many tires at the front as are needed? If the answer is no, then the suspension needs to be redone...and, honestly, that might mean it's time to throw in the towel...although, with all the $$ you've invested in the climate control system, and since you should get a good long time out of the suspension after it's been redone, if you like the car overall, maybe it's worth spending the $$?
new steering gear box - Have you tried tightening up the old box? You'll need to replace the box sooner or later, but you can buy a surprising amount of time by tightening up the box...just keep in mind that the allen-head bolt that tightens up the lash needs to be turned counter-clockwise to tighten the lash.
new oil hoses from oil filter - That one's a fairly common one...my friend who bought my '83 300D from me had towcat's shop do the work last winter, and IIRC spent about $300. Money well-spent IMHO; it's a dirty job involving removing one engine mount...but, again, once it's done, it's done and the replacement hoses should be good for a very long time.
turbo rebuilt - How bad's the turbo? This one really surprises me...OTOH, you mention further down that the timing chain's about due...IMHO both of these are indications that the car's routinely gone way too long between oil changes. With regular oil changes, the timing chain shouldn't be stretching this quickly, and the turbos on these cars generally do well.
trunk seal - Was the car a desert car to begin with? In the Southwest, I wouldn't be surprised by that, but I don't know how long rubber components would typically live in Indiana.
hood release cable and handle - I've seen this on a few other cars...generally, the cable needs grease and/or a gorilla's been pulling too ******* the handle :D
body work & paint - Paint on '80's cars seems to never last...although, unless you're getting cancer that may affect the structural integrity of the car, IMHO this is more a matter of personal preference than anything else.
driveline flex discs - IMHO take care of both of these ASAP...I've heard some horror stories about flex discs failing and the driveshafts wreaking havoc on the underside of the car :shocked:
driveline carrier bearing /
fuel cap seal - Should be a simple and cheap fix
side trim molding clips replaced - Again, should be simple/cheap...I think those clips are something like $0.50 each.
timing chain is about due - See my comments about the turbo...timing chains typically don't stretch this badly this quickly unless someone (either you or the previous owner) has been very bad about keeping up on oil changes.
Given that the car's getting up to 200K miles and sounds like it's been neglected a bit (whether by you or by the previous owner, I can't say), IMHO that list isn't unusually long. I would go so far as to say that, in my opinion, if these issues are addressed and you keep up on routine maintenance going forward, your maintenance list in the future will be much shorter. Keep in mind that, if you use quality parts particularly in the front suspension, you should easily get another 150K to 200K miles out of the components...and, granted I've never owned a Toyota (I don't buy Japanese products when possible), but I don't think that there are very many vehicles on the road that can get 200K+ miles out of front suspension components. One nice thing about M-B's is that, if you use quality replacement parts, you should get as much if not longer life out of the parts than you did from the original parts...so, looking at the climate control as an example; you've already spent a good chunk of change rebuilding it; barring a compressor failure or similar, you should easily get another 150K+ miles out of it.
In the end, it's your call, but I still contend that the W123 chassis is reliable and will last a long time if taken care of properly...I vote for keeping it unless the front suspension's just too thrashed to do anything with.
Just my $.02...
m67tang
lawrenceburg IN
Well, thanks for the input.
the turbo & timing chain are only due based on mileage recommendations that I read.
The A/C was desperate since I have small kids and it was a very hot summer, I replaced the compressor too.
On lower suspension THe ball joints are going bad quickly along with all rubber bushings on the lower suspension. so its not tires, its just a falling apart lower suspension.
as for flex discs- I feel a shimmy in driveline from the carrier bearing, if I take it apart I will replace flex discs too, since I'm right there. trunk has a leak so I need to fix it.
I would sum it up to say all the natural rubber is decaying on the car. I guess I need to make a choice.
The Warden
MiB Impersonator
I don't know if this is the same case in Indiana, but in California, decaying rubber is just a fact of life with ANY vehicle...on my truck, every piece of rubber on the vehicle either has been replaced or needs to be. The point I was trying to get at with the suspension is that, unless the ball joints and rubber bushings are in bad enough shape to throw your suspension out of whack badly enough to eat tires, I would probably just live with it.
As to the turbo...the only M-B's I know of that have had turbo problems were '85 California emissions models that had that stupid trap oxidizer behind the turbo. Certainly, I would check the center bearing for play before condemning the turbo...I rather doubt that anything is wrong with it.
Regarding the timing chain...the next time you do a valve adjustment, you'll want to check the stretch. The simplest way to do it is to bar the engine over by hand until you get the mark on the cam gear aligned with the mark on the tower (the marks are on the back). Once the marks are aligned perfectly, look at the harmonic balancer and see what mark the pointer's on. It should be around 2 degrees, but anything under 10 degrees is considered acceptable. Again, unless the oil change interval's been severely neglected, the chain stretch should be within specs...I've seen engines at 300K+ with original timing chains that were still okay.
Like you said, you need to make a choice...on the one hand, you don't want to throw good money after bad; on the other hand, you've already poured quite a bit of money into much of the most common issues and shouldn't have any more trouble for a long time with what's already been addressed. I'd be lying if I said I was unbiased; I love these cars and would still be driving one except that the last one I had did very poorly for fuel economy and I have pressing family matters that's having me drive 800 miles round-trip on a regular basis...but I would lean towards fixing the remaining issues and keeping the car another 200K miles.
Just my $.02...
JU57US
