1988 F250 Extended cab for sale
Trikebent
Kent, WA
7.3 IDI Burgundy Ext/ Red interior
As Bought
  • 5 speed manual transmission
  • Original radio
  • Arrow conversion to Dually (Factory?) has door sticker from Arrow
  • Banks 1st gen turbo/EGT/Boost (new EGT probe installed)
  • Mitchell splitter Direct/Under
  • 20 gallon aux tank under bed on Pass side (51 gallon useable in 3 tanks)
Since Purchase in last 13,000 miles
  • Pillar Gauges/ Trans Temp/Water temp/ Oil Press (Autometer)
  • Engine coolant filter, Napa
  • All fluids/oils
  • Front brake rotor & pads
  • Front bearings replaced (Timkin)
  • Radiator (Plastic/Aluminum)
  • All under hood hoses/belts
  • all new AC system, R134
  • Geared Starter
  • Block drains replaced with petcocks
  • Firewall re-enforcement kit
  • Firewall re-sealed
  • Replace pedal assembly
  • Injection pump (Rebuilt by H&H Diesel, Fife WA)
  • Injectors (Rebuilt by H&H Diesel, Fife WA)
  • New Injector return lines / caps
  • Clean/ re-seal cab roof seams and windshield (Now leak tight!)
  • Clean Cowl ‘pockets’ & drains both sides
  • Remove/ clean entire interior
  • Additional sound deadening (Dynamat) floors, wall, roof
  • Replace Heat & A/C flapper door
  • 4 USB outlets in cab
  • 300 watt (?)110vac inverter in cab
Additional parts
  • Hood (Original Burgundy)
  • Both doors (Original Burgundy/Silver)
  • Front bumper, used/straight
  • Pass side dually fender, aftermarket (Original Burgundy/Silver)
  • 2 tailgates, both white
  • Original brass/copper radiator
  • Original pedals (Cracked support)
Issues
  • Front fuel tank gauge not working
  • Rear tank gauge works
  • Aux tank gauge is intermittent
  • Truck has been re-painted and re-paint is peeling
  • Damage to both doors
  • Damage to cab behind drivers door
  • Hood is kinked on drivers side
  • Pass side dually fender has multiple holes, cracks
  • Bed was damaged and re-paired. Old repair has failed and bondo is coming off top of bed rails
Location is Covington, WA, (Between Tacoma And Seattle)
Asking $6,000
