divemaster5734
Having fun and games with that 3/8"(?) nylon fuel line.
Hoping to eliminate the short piece of nylon line that runs from the tank selector to the holly pump I mounted around 12" from there.
The port that's used is the rear tank set, which of course face up, directly into the bottom of the top of the frame rail.
Only a 90° fitting will fit.
Has anyone ever cut the nylon line from a connector to attach 3/8" hose?
If that won't work, what are those fittings?
I found far too many options online for my limited knowledge of these systems to decipher.
Thanks
Thanks
