'90 7.3idi Harmonic Balancer Fit Years
divemaster5734
Olympia, Washington
Been searching for a new harmonic balancer for a '90 F350idi.
Going through online parts suppliers it appears as though the '88-'91 model parts are scarce.
That said, '92 and up are everywhere.
I'm wondering what's the difference, if any.
For instance, I had to get a new clutch/slave assembly.
I couldn't find anything until I realized the '92-'97 were an exact fit, but with upgraded components,(steel master and steel braided hydraulic line instead of plastic), a lot cheaper, and could be found everywhere.
Which brings me to question this latest issue.
All the listings I've found for the 7.3 harmonic balancer indicate "serpentine".
That confounds me because there is no actual belt pulley permanently attached to the balancer, rather, it's mounted in front of it.
All the pictures also show no pulley.
I'm planning on grabbing a dial indicator to check dimensions and compare to a newer year model.
I was just wondering if anyone else has already visited this issue and what your resolution was.
Thanks.
Rockauto has 3 different ones? Only 2 are available though. It's a good place to get part numbers and do a google search to see if someone else has one also.
Guessing on the bolt pattern possibly being different ( maybe)
Definitely not. I have the stock balancer on my truck from 88 and the serp pulleys bolt right on.
My truck VS my in laws 92 I couldn't see any visual differences between the balancers.
divemaster5734
Olympia, Washington
Can't say I understand why they would delete the earlier years, unless the new model's are of better quality.
Heading out shortly to a chain store to compare.
The only ones listed for 88-91 are also listed up to 97, so obviously interchangeable.
Which only opens up a Pandora's Box that will now require more extensive research into every future part purchased for this project to determine which design is a higher quality part.
I'm betting God had a chuckle when I totaled up the anticipated budget of the engine/transmission swap.
I'm almost at the 2x level now.
But then, it's gonna be so cool when it's done...lol
Clb
Another old truck
nannyfornia
Wait
Wasn't there something about the crankshaft ballance with the dmf setup?
I didn't change mine when I went from dmf to smf, and my in laws truck is an auto and balancer still looked the same.
  • Like
Reactions: Clb
It's been a long time since I've looked at one, but I'm pretty sure that the Power Strokes didn't use the same balancer as the IDIs. Those must be for gas engines despite their listings.
The only ones that would be different for the IDIs would be the ones for the Factory Turbo engines.
Check out this guy, he is located in Redding, Ca.
