Rdnck84_03
Those type bushings are always a pain in the ars. I almost asked a couple days ago if you were planning to replace them.
James
James
James
I am very interested in seeing these pictures, kinda want to use a 6.0 filter instead of the Hypermax adapter for the stock intake.The 6.0 Filter do flow well.. I think I’ve read in on a 6.0 they are good for over 500 horse before they are a restriction. The element last a really long time…. And filters very well. One think most don’t realize is the drivers side battery tray also has the mount for the filter on it. On a 6.0 the filter mounts between the engine and battery, just behind the core support….. I do have pictures somewhere do a 6.0 filter setup…
So as of right now, I guess it doesn't roll too far.As of right now there's something wrong. One of the wheels locks up.
So as of right now, I guess it doesn't roll too far.![]()
Isn't that a little like putting the cart before the horse?Today I finished installing the new hitch.
Isn't that a little like putting the cart before the horse?![]()
Hopefully your tank will go back in with the hitch installed.Much easier to do without the fuel tank in the way
I had to pull the hitch off of a 95 powerstroke to get the tank out. We fought it for over an hour trying to get it out before finally giving up and pulling the hitch.
James
Quote that and bookmark it. Those aren't that fun to install with no hitch there.It should.
