Thanks for all the help. I was torn between fixing it or going with a different truck. This truck has 170k on it 4speed, new tires, dually, long bed, gooseneck hitch, dual tanks, and wvo kit. I got the truck for $2500 and so far have put a ner rad, water pump, and the wrong stat on it. I don't think that I have a chance getting that money back out of it blowning smoke and I don't think I can replace it for that either. After reading up in it and finding this forum, I think I'm going to fix it and use it.
I plan to take it to a buddy that is good with diesels. Let him check the heads and replace if needed. Also I'm going to replace the head bolts with APR studs, and check all the injectors and glow plugs. Is there anything that I should know before going in? Which are the best studs and gasket? I don't think I will ever add a turbo, I just don't want this to happen agian.
Agian thanks for the help and info. This fourm has some great knowledge in it.
