trackspeeder
Stone crusher.
Majority of the time you will know when the converter is slipping. You will get a shudder when the clutch locks.
That's another thing it doesn't do is kick down. I forgot to mention that. I've gotten it to kick down a gear two times by putting the pedal to the floor, but usually it still won't. I also meant to get the axle code to see what gears I have, but I forgot. I'll have to run and check that.
If I am cruising in 4th gear at around 2,000 rpm, and flip the switch, it will drop about 200 rpm if not 100. But if I am going along with any amount of throttle at 2,000 rpm and flip the switch, it darn near doesn't even change anything. Even if I am just cruising and I lock it it, I can raise the rpms like it's not even locked. If I do let off, I would say it falls back into a notch like you said.
I also have a 95 Powerstroke E4OD that I might possibly have freshened up, and if I have read right, I will just have to use my solenoid pack, and get an IDI torque converter. Only thing that really sucks is there is litteraly no known transmission builders or even shops around me. I also know of a hidden IDI with a ZF5, but all of my vehicles are hand shakers, and I was really looking forward to having one that I can just plop in D and go.
Yea I kind of expected the worst on this one. Really sucks being I way overpaid for the truck already (granted it is SPOTLESS and if you want that in this neck of the woods you're going to pay for it)
If I were to have the 95 trans done, is there any updates that would be good to have done? Or by that year are all the updated parts in it?
How does this converter look? It's a billet cover single disk with a lifetime warranty...
https://ktperformance.net/i-6685257...MIp5OY3b7E2QIVzrXACh0iFwUMEAQYASABEgL1MfD_BwE
9K#. I was foot on the floor pulling a hill, jawing with my wife, switched out of OD still foot on the floor. Trans down shifted and the converter tried to lock. Grey smoke, loss of forward motion, home on a flat bed.
Welded one converter-to-flexplate nut. Blued flex plate at converter mount holes. Melted snout off filter. Melted plastic drain back valve in pump.
I had paid for a triple disk billet converter. Had a converter shop open it; not the one I got it from. It was a single disk, with no friction materiel remaining.
If you are going to keep a truck, get a triple disk, billet converter and a metal drain back valve.
I ran LEDs into the cab from all the solenoids.
