Spark
Well now that I have my truck running good, I have a couple questions on the trans. First off, I seems to shift very fast through the gears. Even just rolling from a stop to make a turn it's in second gear before you're out of the turn, and third isn't far behind. I have checked and adjusted my FIPL sensor, and that reads right. Second, I thought my torque converter wasn't ever locking, so I rigged up a quick lock switch, and it turns out it was actually locking the entire time it was in 4th gear... but it's either slipping, or not locking all the way if that's possible. When you lock the converter in 4th gear, it only drops the RPM by about 200 if that. Then once it is locked it still raises RPM substantially if you give it throttle just as if it wasn't even locked. 55 MPH the truck is almost at 2000 RPM. Does it sound like the trans is going to have to be gone through soon? Thanks!
