Sudden Unexplained No-Start
ormgott
Lebanon CT
My '86 F250 with '92 7.3 has stumped me... Now it's stumped the repair shop. -cuss Was running perfectly, then just wouldn't start. So I replaced the lift pump with electric and that didn't work. Replaced the IP and got fuel where it's supposed to be but still no joy. I get some pressure through the exhaust but also through the intake along with fuel vapor. I gave in at that point and took it to a shop with knowledge of that model/engine. Now they're saying they are stumped as well, and a complete teardown is prohibitively expensive. Anybody have ideas? :***:
ormgott
Lebanon CT
Yes to fuel shutoff working. Fuel is getting to the injectors. Zero response to fuel or safe use of starting fluid. Batteries and starter are full up to ***** as well.
ormgott
Lebanon CT
Pump was pulled clear of the gear and new pump aligned and slid into gear when installing, and engine/transmission weren't moved. I'd suspect a cam misalignment with the apparent compression release through the intake but can't see any way for that to happen.
ormgott
Lebanon CT
If it was just the pump timing gear being off I'd think it would still respond to some extent to ether
Philip1
Northeastern Nevada
Are you getting any smoke when you crank it over? If yes check glowplugs and starter for proper operation (make sure the starter is spinning fast enough). If no you are likely not getting enough fuel through the ip to fire the injectors. These engines still need fuel to be injected to attempt to fire even with either.
ormgott
Lebanon CT
Starter and batteries are good. Glow plugs are good. As I said earlier there's lots of fuel fog in the intake when cranking. Also feel airflow coming up from intake. Some fuel fog from exhaust as well.
riphip
Memphis, TN.
Do you still have the water separator on the truck? If so, have you pulled the ring lately?
ormgott
Lebanon CT
No recent work done to engine prior that I know of. Bought truck about 2 months ago. Started and ran fine for several weeks. Got in one day and cranked it over, fingers slipped off the key. Went to start it and perfect crank but no fire from then til now. Fresh filter.
gandalf
Senior Member
CA &/or Maine
You changed the fuel filter? Did you fill the new filter before you installed it? If not you have a lot of air to work through the injectors before they get any fuel. If that is the case you'll probably have to charge your batteries several times before it fires.
When you're cranking the engine crank for only 20 seconds, then let the starter cool for a couple minutes. The starter is fighting a high compression in that engine, and having to work itself hard. It will overheat and burn out if it gets too hot.
