Shocks? BrAke lines?
Bootzz
Louisiana
How do I know what size shocks to get when I do my lift?
Ill be right at 10"
And will I need longer bake lines?
Anything else I'm missing?
I wanna have it all before I start this
Mulochico
Modesto, Ca
Definitely longer brake lines!!!! I only went with a 4" kit on mine and the rear line was to short and the front were questionable.
Summit had a kit that worked well. Only problem for you is it was only for lifts up to 6" if I am not mistaken.
bigtex
trial and error
Ft Richardson, Ak
yes on the longer brake lines and just grab some long travel shocks after you measure the distance from full stuff to full droop on all four corners, and then buy accordingly.
JFMac
