Replacing sulpher in #2
Clb
Another old truck
nannyfornia
So been thinking on the additives threads here.
So many different products ...
So my first question, those using 2 stroke has anyone noticed an egt spike?
Brb
Edit
Oops
Well anyhow the last thing here I dug up is literally 15 years old as to actual testing ...
Then it was optilube.
Aint seen powersmoke in a coonsage he was an a pro lube guy.
I like in lala land it rarely hits sub 30* mostly pulling summertime, so the gallon of stroke is just bout gone ant new favorite snake oils?
Besides 2x....
Clb
Another old truck
nannyfornia
Yea I clean forgot I was dosing the ole girl with 2x...
Got 2 full tanks to burn off someday.
Note 2 self
Make a note...
Lol
Rug_Trucker
Pertnear Nashville TN
When my truck was on the road I was dosing Honda ATF nice purple fluid. Did it do anything? No idea. I can say in my car Marvel Mystery oil has 198K OEM injectors looking brand new. It is 2oz per 5 gallons for gasoline. I do it to lube the fuel pump mostly. **** has gone up 35% lately!
nelstomlinson
Delta Junction AK
I've been using the cheap Walmart 2 cycle oil. It's designed to lubricate while diluted with fuel, and to burn without leaving any ash.
Also, that evaluation of diesel additives found that it actually works, a little, at reducing wear.
I add a pint per tank, so a little more than an ounce per gallon. It turns the diesel a light blue. Probably should use more.
