quick interior question!
alienturtle
Human
Ripon, CA
im about to order my 2nd vinyl replacement mat. The first one i ordered came in a ACC box and was NOT molded at all. That is now gone and i still want to keep the vinyl floor. I am about to order another kit and ACC seems to be the only people that make one for my truck. I spoke with another member here that purchased a kit of his crew cab and it fit like a glove. On that note i will give them another shot. I called ACC direct and that said they have had no issues with fitment.
They offer a couple different ones and i would like to make 110% sure i am going to order the correct one. I have an 1989 F250 super cab (ext cab) 5 speed 4x4.
they have
16619-89 CARPET 1989 FORD PICKUP EXTENDED CAB 4 WHEEL DRIVE 4 SPEED GAS OR DIESEL
16618-89 CARPET 1989 FORD PICKUP EXTENDED CAB 4 WHEEL DRIVE GAS OR DIESEL
i know it says carpet but once you select it you can get the vinyl
im going to order the 16619-89 correct!
anyone else ordered one.?
Hard to say the 5sp is not listed and has a different trans tunnel size than the 4sp and IIRC that shifter is in a completely different location thus the hole would be...if it's pre cut...maybe you should call em find out if hole is indeed cut? Or perhaps they have one for a 5sp
alienturtle
Human
Ripon, CA
when i called ACC they said the holes are not cut. Which works out great for me because i have the dodge nv5600 6 speed behind mine now. I was wondering if the 4sp and 5sp have different tunnels?
alienturtle
Human
Ripon, CA
great so what do i do to get a vinyl kit for the 5 speed. i dont even see replacement carpet kits for the 5 speed
alienturtle
Human
Ripon, CA
i just thought about this. i purchased a tranny tunnel for an automatic from a member here and i just cut the hole where i needed it. Im just going to order it for a 4x4 automatic and hope the best.
ntjapkes
