Black dawg
The valve is probably fine, but look at the contact marks on it after lapping to be sure.
No nothing seemed odd, I already ordered studs. They fit a 7/16ths 12 point so I guess I do have the 6.9The crosshatch is a non issue.
Anything out of the ordinary with the headbolts surrounding those cylinders?
Yes that's ideal. Captain, if that's all you're seeing, I say to check to make sure that there's not too much valve guide play and run them for a while. Others may say differently, but I feel that you'll be ok for a while longer yet. I'm under the impression that you're thinking about a rebuild on this or another engine in the future so I'd save the money from going farther with the valves right now and put it toward that future rebuild. By the way, you did lap the valves before doing this test, right?I would think you wouldn't want to see anything escaping.
No I didn’t lap the valves everything looked so perfect I just did the test. Yes I have no fear of opening the engine again I am just happy to get somewhere around 100k out of it maybe less maybe more I just don’t currently have the capacity to do a full rebuildYes that's ideal. Captain, if that's all you're seeing, I say to check to make sure that there's not too much valve guide play and run them for a while. Others may say differently, but I feel that you'll be ok for a while longer yet. I'm under the impression that you're thinking about a rebuild on this or another engine in the future so I'd save the money from going farther with the valves right now and put it toward that future rebuild. By the way, you did lap the valves before doing this test, right?
I'll bet that if you lap the valves and do the test again, you won't have any leakage. All you have now is small imperfections on the valves or seats so lapping them should clean that up.I don’t have lots of money for machine work so I think I will run it.
