Isaac Ristow
Going to look at this Perkins T6.354.4 on a 73 1 ton chev frame with a 5 speed OD Clark trans (model 280VO11) and a 3 speed Spicer brownie box (model 5831) Engine is a reman and supposed to run very well its also a late dot4 engine with the kinda rare Bosch VE pump instead of the usual Lucas CAV pump that's normally equipped on a 6.354 Perkins. My goal is going to be put engine trans and brownie box in my 85 chev C30 that is a original 6.2 truck and for what I use it for normally grossing over 23-24K lb. combined the 6.2 isn't cutting it even with the 6.5 turbo on it. I've been told a better turbo and some more fuel on the Perkins I'll be roughly 220-250hp and 550-600ft.lb. Also the Clark has a OD of .80:1 and the Spicer has a .73:1 OD so double OD will mean good freeway RPM and also be able to split gears with the Spicer for towing. I'll attach some pictures
