I have my new R&D Injection Pump installed, and set to 10 deg.
It`s a 86 6.9 NA engine.
I have backed off the Idle adjustment screw all the way and it idles high.
Set timing with the Ferret and Inductive timing light. Shows 860 RPM`s.
Engine runs good, but accelerating throws out super black smoke, way
more that the old Pump and Injectors.
It definitely runs better so far than with the old parts.
Doing some reading, the fuel screw behind the Triangle plate on the Pass
side of the pump, if I turn it back one flat, will that idle it down?
That would cut the fuel down.
With the the old pump, there was no problem with idling it down with the
idle adj screw.
idle adj screw.
