Max pump settings
Nessmuk
Nys
How do I adjust my injection pump to push as much usable fuel that it can?
86 CUCV, 6.5 Navistar, ARP Studs top and bottom, HX40WII Turbo, 3 into 4 into 5 inch exhaust, 14 ply 9-16-36 bias ply tires, H.O. Water pump, Hi CFM fan, 4 cored industrial radiator, Remote oil cooler, Dual alts, 4L80E transmission, Twin sticked NP205, 2 transmission coolers, 4010 u- joints, Water methanol injection, Rebuilt 4911 DB2 injection pump and hi pop injectors, Steering cooler in radiator, Detroit locker, Dual tanks, fuel pumps and filters, Oil, Trans, Water temp gauges, Pyro, Tach, Boost gauges, Oil press, Fuel press, Volt gauges, Trans press gauge.
Dieselcrawler
Professional wrench holder
Quakertown Pa
Did they or you install the 6.5? Is it mechanical or electronic? 85 should be a mechanical 6.2
May not be correct, but even the "newer" ones I saw had the mechanical pump.
Have you played with the pump at all?
What's your max egt?
Dieselcrawler
Quakertown Pa
94 and up are an electronic pump.
Even the hmmwv?
Maybe I just wasn't around any that new. Lol
I knew the civi pickups changed in 94.
BrannonB
