COMPLETE ENGINE BOLT TORQUE SPEC FOR THE 7.3/6.9
Status
Not open for further replies.
cam to crank gear lash IH spec =
0.0015 - 0.013"
also adding other info ive found along the way
Knuckledragger
Payson, AZ
In the torque list, it says not to use new bolts for the oil squirters. Why?
some people have said that new bolts will worth themselves out.
I tried finding the thread where I read that, but failed.
ive heard it mentioned a few times, so I thought it would be good to share.
rlb245
Cody Wyoming
just use a general torque spec
1/4x20unc 7 ft-lbs
5/16x18 unc 14 ft-lbs
3/8x16 unc 24 ft-lbs
7/16 x 14 unc 38 ft-lbs
1/2x13 unc 60 ft-lbs
that should get you close
genscripter
Inglewood, CA
saburai
When I tore down my 7.3, I documented all the bolts and their respective threads. When I reassembled it, I diagrammed out all any necessary torque sequences and identified them. Here are the images from my collection, and I added some 6.9 IDI info as well, and I identified any differences between the IDI truck and IDI Van engines.
http://www.nickpisca.com/diesel/engine/7-3-idi-torque-specs-and-bolt-dimensions-with-images/
Wow! That's super helpful, thanks for your efforts.
Status
Stubburnjd1
Staff online
