Clutch pedal return
Good morning everyone, looks like I could use a little help on this, my two brain cells bouncing off each other this morning are struggling.
Yesterday morning I started having issues with my clutch disengaging. Had to push it hard to the floor.
Last night I replaced the master cylinder. Veririfed clutch pedal bushings all good, no firewall flex. Felt good on a quick road test.
Hop in this morning, same issue. Got to work. Found that the clutch pedal isn't fully returning all the way up on its own. If I grab the pedal and pull it, it has another full 2 inches of travel. Once it's up, it'll stay up, then the clutch works fine for one press. Then gets stuck again.
This is a weird one for me, sign of clutch slave going out? Bad return spring on the pedal?
FrozenMerc
SW Missouri
I would definitely start at the slave, make sure it is functioning smoothly, is in good alignment with the throw-out arm, and not binding. Then pop the bellhousing cover off, and make sure the throw-out bearing is not getting hung up, and allowing the clutch to fully engage.
On lunch I pulled er in and had someone help me check it out.
If I manually push the clutch fork in, it retracts quite a bit, and leaves thr fork loose. No obvious binding of the release bearing. Then takes two pumps to get the slave cylinder reset, and pedal is back where it was before.
I saw somewhere on ford trucks forums that you can take the 19mm nut off and move thr clutch pivot one tooth over, Andy advice against doing that?
Well, I tried it anyways since I have some downtime at work. Here's the weird part, before I adjusted it, to get the master cylinder rod to align with the clutch pedal, I had to push the pedal down half an inch to align them. I moved the pivot bit over one tooth, now I had to compress the master rod a quarter of an inch to align it.
Pumped the clutch a few times, opened the bleeder screw to relieve pressure when clutch released, now it feels rock solid. I also cannot compress the slave cylinder by hand anymore.
So tell me, did I just make things worse? Gonna drive home and see how it all feels.
hacked89
Bucks County PA
When you put a new clutch swing arm on or do a Heim joint mod you adjust the swing arm to take any slack out of the clutch master rod to pedal assembly. It sounds like your describing trying to compensate for a different issue using that. What I’m understanding from your posts is you have a hydraulic issue either air / one of the cylinders.
There’s not much else that comes to mind that requires “pump”’ to create pedal return. Mechanical issues are more static.
I know its a fairly simple system, and it's not supposed to be adjusted, but the symptoms dont pan out to leaking hydraulics or worn bushings.
While I was under there I shook down the linkage again to verify the pedal bushings are fine still.
Maybe I need to get an adjustable push rod like ive read some people do to snug up the play.
In the meantime, my clutch engagement is now a little bit more than half a full press, and when I let it go completely I can still grab the release fork and jiggle it, so its not keeping constant tension on the bearing at least...
I haven't had any food luck with doing that. Either it's too far or not far enough, depending on which way you move it, from my experience.
I'll strongly second this. I really think it sounds like you're got air in the system somewhere. I haven't seen a clutch pedal not return with no air in the system.
I'll try bleeding it again. The drive home was definitely unpleasant, I prefer the clutch disengagement to be closer to the floor, but not AT the floor.
Another solution I have, I found that the 1985 6.9 idi came with an adjustable push rod for the clutch master cylinder. I could get that to drop in for now too.
hacked89
Bucks County PA
What’s your thoughts on why you’re not buying a pre-bled kit & heim conversion? It’s relatively low cost compared to other things on your truck but I understand if budget is done.
Budget isn't the problem, its my timeframe, my trip, we head out Sunday and its 150 round trip, then immediately after we get back I head out to another trip that is 120 round trip, so won't have time to do a 'correct' repair.
I also could use a link as to what the heim conversion is....
Wait, is this all it is?????
hacked89
Bucks County PA
Got you. I use these kits: https://store.dieselhub.com/products/heim-joint-mod I also do bushings (OEM ford) and new clutch swing arm
I'll bookmark that for now,
In the meantime i just went down to the hardware store. Can't believe how easy that was. I spent more time trying to get the shaft out of the master cylinder.
I did cut threads on the shaft, 3/8 x 24 nf, got a threaded heim, and adjusted it until all the play was just barely taken out, then locked it with a lock nut.
Took er forfor a quick spin, its so much better now. Cost was about $22 but the heim is longer so bye bye clutch safety switch. I do like having it in there so maybe I'll swap it back later.
Using the threaded Heim Joint is a more secure set up than most
of the write up cutting off the ring end and slipping it into a joint
with set screw. Mine has the set screw, and red lock tite.
I had a Peddle assy from PNP out of an 85 I had sitting round for
several years. Bought the new Plastic bushing`s from the Ford Dealer
and took the thing apart to clean it up and paint it. With it apart, sure
made it easier with the Clutch lever in a Vice to grind off the weld, and
punch out the pin. That thing wasn`t too bad, but the assy off the 86
was worn 1/2 way through. The Heim Joint took out all the slop and made
a nice tight clutch throw.
nosrednA
