nelstomlinson
My van doesn't have a tach. It looks as if it should be pretty straightforward to stick an f350 instrument cluster in there, but the ones I'm finding on fleabay say '92-'97, which likely means powersmoke. If I do wind up with a powerstroke tach, will it work right with the signal coming from the IDI engine?
My plan is that I'll get an f350 cluster, insert the PSOM from the van, adapt the two outer connectors if the pickup and van EVTMs indicate different pinouts, and that should be all it takes!
