C6 Lock up torque converter.
I didn't see where the description mentioned a locking option. It it does lock, that's a great idea. I've just bought a reduced slippage convertor to use.
XOLATEM
Virginia... in the brambles
I intend to say this in the nicest way possible...but I always have been blunt...
and...that tendency has always got me into trouble...but...honesty is the best policy...
I am going to say that I am sorry to bust your bubble right now before I shoot my mouth off...
Here goes...and like Larry The Cable Guy always says..."Dear God I am sorry...."
There is no way right now to install what is commonly accepted as a 'lock-up' torque convertor in a C-6 transmission...and get it to work as generally expected....without major re-engineering of the input shaft, pump, case and valvebody....
That advertisement is a mistake...probably by an IT 'pro' that doesn't know anything about transmissions and torque convertors.
On a diesel application the best you can do with a C-6 is to get the lowest stall possible to make use of the torque curve you have at an extremely low (compared to gas engines) RPM range...
If someone is talking about 'lock-up' in reference to a C-6 then they must be referring to an extremely low RPM 'coupling point' where both the impeller and turbine are spinning roughly the same speed under load...
There is no 100% mechanical locking together of both elements at any time...
Now...what can happen is that the component that is splined to the transmission input shaft...it's rotational speed can exceed that of the housing that is bolted to the engine...when you are coasting...especially downhill...
But...
I hope we can put this fallacy (that you can make a 'lock-up' torque convertor work in a C-6..) to bed, now...
There, I said it...
And to top it off...I'll bet you...uh...your first welding project....
Well...it was better than betting your first-born...
Just my unasked-for .02...
P.S. If you want a true lock-up torque convertor in your truck...the best way to go...(in my opinion) is a version of the E4OD...if you have ever been inside of one...it is a big, beautiful unit...that I would be proud to drive...if I had built it and had intimate knowledge of every part I put into it...
Ok...now I am done...
Cant Write
Placerville CO
@XOLATEM has invisible holding cup holders on his dash!! A conveyor belt to transport, and an open window to dispose of the contents and biodegradable cup.....:dunno;Poke:rotflmao although I think his electronics (driving) sometimes goes into “tilt” mode like the old pinball machines
On another note, I’m a blunt person too, and tell it like I see it. And the people who don’t know me think I’m an A-hole
XOLATEM
Funny you would mention that...I was thinking recently about finding an old pinball machine to fix up...
A phenomenal score would be one that is just like the machine I used (on my time off...sure...) when I worked at a gas station.
There was a gambling pinball machine in the back room and it paid off occasionally...the thing had a 'reputation' and a lot of the locals lined up to try their luck...
That is one thing that I would bring back from the 70's...I wish I could remember which one it was....
It was suitable for a drink-holder, as well....
Cant Write
Placerville CO
On a serious note:
@Darrin Tosh why do you want a lockup converter on your C6?
@XOLATEM how much slip at cruise is their on a low stall C6 converter? 100-200 rpm?
If only that much I wouldn’t wanna potentially add a weak point to a robust trans.
Also, not sure if Ford did. But Chevy did make a TH-350 and a TH-350c. The “c” denotes lockup. Based on what Xolatem said above, the input shafts must be different.
Clb
Another old truck
nannyfornia
Once upon a time, the drag race guys toyed with
Clutch Converters, not the same as a lockup solenoid ...
That's all I got.
XOLATEM
Damifino....for me to answer that truthfully we would need a test vehicle with a C-6, a super-accurate tach, an input speed sensor and a meter that would measure the sensor pulses and translate that to RPM...
Actually...come to think of it....if we had a manual valve body to take off in 3rd range and a VSS and a meter that would measure the sensor pulses and translate that to RPM...we could give any torque convertor a 'truth-in-advertising' test...
on a 350C...yes....input shaft, pump, case, and valvebody...as well as the torque convertor.
Ford did take a basic C-4 and convert it to mechanical lock-up...but it was not long-lived...the units would fail spectacularly....and the convertor rebuilders would disable the lockup function...
The cupholders were left alone, though....
But...
There, I said it...
I knew this was coming, great job. I was skeptical, but I didn't have any of the absolute data.
Absolutely brilliant, bravo! BRAVO!!!
I'm surprised cupholders came up on this. I figured someone would have mentioned mounting cupholders on my rearview mirrors, Lord knows I thought of it.
And I want to go ahead and apologize on behalf of the Oil Burners to Mr @Darrin Tosh , for your thread being hijacked by "cupholder discussion ". This hasn't happened in a while, but just like COVID, it's bound to flare up from time to time.
Oh, and just to add to @XOLATEM s deal on the C6, I'm no guru, but to make that really work you'd have to reengineer the valve body, case, and front pump. By the time you were done you would have a different model of transmission, if I know Ford model number stuff well enough it would be called the "C-6E", and it would still suck behind a under powered diesel V8. So your best bet is to save your money do a ZF-5 swap or at least a T-19. And use the C6 case for a mailbox and the internals for cupholders and interesting paper weights and conversation pieces........ WAIT!!! Don't do that with your C6, I'm sorry, send them to @hacked89 in Pennsylvania! He knows what to do with C6s!
