Just make sure the Black wire on the controller has a good ground. Controller won't cycle if it's not,
FIXED!! WTS light works and fires right up without the pedal being touched!! Heck yea! Thanks everyone for your help!
Quick test: Use a cheap test light (bulb style not led) hook the clip to bat. positive terminal, remove the wire from a glow plug and touch the tester to the actual glow plug. If it lights up that one is good. Wiring must be disconnected from the glow plug to be tested. It's usually one or two dead ones.
Sent by wing, prayer & ATT
Well. In my opinion, id rather spend!$85 and 30 minutes.at autozone than over $100 andtwo hours on glowplugs..just my .02
