rip van sparky
Lowering the compression ratio doesn't exactly add more boost. What it does is increase the volume of the combustion chamber. Therefor your turbo will fill a much larger area to the same pressure as before. You will then have a lot more fuel and air expanding (burning) in the same displacement. You are burning the same amount of air/fuel as an engine would be that has a much larger displacement. That is the reason you have to lower the comp ratio to be able to take full advantage of the turbo. The powerstrokes and cummins have 17 to 17.5:1 comp whereas our idi's have like 21?:1. If we were to put as much air as they do in our engines they would simply not be strong enough to keep from blowing apart from the pressure. If you enlarge your combustion chambers to the same size then you could put the same amount of air/fuel in them as high perfomance diesels do (in stock form). The problem is that do to the design of our engines it is almost impossible to get them to start at 17:1. I would think that moderate lowering of the compression ratio to say 19 or 20 would give significant gains in power and still be possible to start. Time and money is all that it would take to find the ideal combination.
