Another starter thread.
Brian VT
Maine, USA
I had a starter solenoid? issue which lead me to decide to upgrade my OEM? starter while I was addressing the problem.
I read here about the nasty top starter mounting bolt and was prepared for the fight.
I bought the recommended? Powermaster starter that I also read was easier to install and gives much better starting.
I got the existing starter off without too much trouble. Knowledge from you guys and my patience was a huge help. Thank you.
Then thunderstorms came in so I was shut down. So I dragged my tools and parts inside.
I commenced to getting things set up inside for my next chance to finish the job by "working smarter, not harder".
I wrapped strips of paper towel around the end of the nasty starter mounting bolt to hold it in place and centered in the starter flange so I wouldn't have to try to stuff it in there blindly after the fact.
Then I tried to set up my socket and extensions. That's when I realized there is a big problem.
The Powermaster starter does not allow for a socket to be used on the nasty top bolt. The only way at it is from the side.
So...at daylight...I guess I will be looking into seeing if I can get at it from the passenger wheel well. Arggh!!!!
I sold my modern vehicle because I wanted something simpler that was somewhat easy to repair myself, like my '64 Ford Falcon.
I'm starting to regret my decision.
I've replaced starters on my cars over the years. I don't think any of them took more than an hour, soup to nuts.
I was an hour into this one just getting the old one off. And I'm not seeing the light at the end of the tunnel for getting the "upgrade" one installed. :-(
ROCK HARVEY
Dayton OH
I replaced mine a year or so ago, and the key for me was a wobble extension. Like you noticed, the starter doesn’t let you access the top bolt straight on. A wobble extension let me get to it at an angle, and made the job much easier.
I've always used just the stock looking starter, with a looong Extension I've never had issues getting to the top bolt.
Hope you get yours in and running soon mate
I'm so excited. This is where the super fast shipping comes into play: think about it, you didn't expect to get the starter for another day or two so if it takes that long to put it on there's no real loss........ always look on the bright side of life (que whistling)
Here are some photos I took back when I replaced my starter, demonstrating the benefit of the wobble extension:
That's some fine "wobble extension demonstrating". Did you hire a hand model? Or is that really you?......I'm kidding, but everything is too clean for my style in that picture.
Brian VT
Maine, USA
I have wobble extensions. No go.
I can't even get the socket by itself onto the head of the bolt on my bench, never mind when it's on the truck. The housing of the starter prevents it. (see picture) Only accessible with an open-end wrench from the side (wheel well?)
I guess my weekend will be trying to get at it through the wheel well and making a custom wrench to get in there or going to NAPA and getting a crappy starter and packing up the Powermaster starter for return.
Who here recommended this starter? Must be someone that installed it when they had the engine out.
Brian VT
Maine, USA
I'm gonna have another angry beer and send Powermaster an email asking ***? lol
You have my condolences, good luck getting that fender liner out
Brian VT
Maine, USA
I just sent an email to Powermaster, fwiw.
Will post their response if they send one.
Glad I don't need my truck any time soon. I guess that's why some folks pay $70K to not have our problems. ;-)
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
I have the old straight style starter and it is a bit of a pain but probably only takes 30 mins to swap out.
I have upgraded to a Nippendenso gear reduction unit that will go in my 86 with the 7.3 turbo. I will then see if it is easier or more difficult.
Definitely harder on 2WD trucks with the long Mitsu style starter. Cant hardly get it in there. Gotta be at all the correct angles. Much easier on my 4WD Bullnose than it was on my 2WD Bricknose
Just recently there was talk of dealing with power master. It was @chillman88. But theyre really friendly and one of the guys on here visited the plant where they're made and everyone there is nice. It's supposed to be like Disneyland or Oz, or something. I can't remember what thread it was on, but they just carried on about how great it is. I want to go myself, definitely on the bucket list.
I like the planetary gear one that O'Reilly sells. But my last one was a dud.
KansasIDI
Wilsey, KS
I’m a Napa man as that’s the only branch of parts store within 40 miles of me, 2 of them within that radius.
Napa stuff seems decent quality, and the one in Council Grove takes really good care of me as I give them lots of business
Like Chillman88 said in a different thread, use a swivel socket. Not a socket and a swivel. It's not Powermaster. It's all of the Nippendenso style starters that are built this way. If you all think that bolt is hard to get to on one of these, you should try it on a Delco-Remy starter. The original style on the early 6.9s.
