Sergey
Hello,
first off, this is not diesel specifc question. By asking here since your expert opinion and enormous coverage are highly valuable.
Here is the background. A couple year ago I replaced power steering pump on my 85 F250 with new, from RockAuto. Not the cheapest, not the most expensive. At the same time high pressure hose was replaced with new. In addition low pressure hose was replaced with new, from local auto parts store (sold by foot). Everything was cleaned, new power steering fluid, bled the hydraulic system.
Worked great since then, but until recently....
Noticed that power steering fluid level dropped. No obvious place of leak. But the low pressure hose is wet on its entire length, a bit wetness on power steering reservoir back and side. Seal is dry. A little bit wet on top of frame where steering box is mounted, but box seals are dry.
And the strange observation: every time I open power steering lid (on a warm or hot engine, to check and to top off) there is a pshhhht sound and momentary push. It certainly seems that there is compressed air in power steering reservoir.
Why would it ? Anyone ween something similar, maybe even on another vehicle ?
Thank you
Sergey
Thank you
Sergey
