Hellos everyone, I’m having issue with my 1994 7.3 idi factory turbo. It seems to start fine both cold and hot, however when it’s warm or hot the idle gets a little rough and while driving it’s a little shaky at low rooms to maybe 1300 rpms and clears up above. Idle is almost perfect when when I first start up and it’s cold. I have a slight haze at idle when cold but it will progressively get worse when it gets hot to the point it will create a cloud of haze. It smokes at throttle between a whitish blue haze and heavy throttle kinda grey to black smoke. I’ve made sure I don’t have any fuel leaks and cracked all injectors which all sound pretty consistent in changing the idle. When cold it feels like it has a bit more power then hot.
