THSIM9’s 1991 F250 Project
THSIM9
Idaho
Started on the wiring process. Dash removed, all unused items (cruise control, door buzzer, etc) have been trimmed out of the harness and I started chasing wires in the engine harness so I can get everything put back together properly.
THSIM9
Idaho
Nice boat
It is a super nice boat. It’s my father in laws. It’s a 1991 (matches the year of my truck) and it looks brand new and runs fantastic. We’ve been out fishing on it a couple times this year already and it’s a blast.
The_Josh_Bear
Western WA
Dang, on the wiring, better you than me! That's a chore. Truck is looking sweet, keep up the good work!
I agree on the boat, I grew up fishing but have barely gone as an adult. I miss it! Smallies are the BEST! I only ever got to catch a few of them, best fighters I've faced in fresh water. My then step-dad took me up to Canada and these dang fish would hit topwater in 30' with no structure or vegetation around at all. It was UNBELIEVEABLE!
THSIM9
Idaho
Wiring fun today.
Completely butchered the painless harness so that my knuckle dragging self could understand exactly where everything was going to land. Got the fuse block mounted, alternator is wired in, actually the entire positive side is pretty much done. I need to start landing wires tomorrow and get the engine bay wrapped up.
The clutch pedal does clear the fuse block. It’s just the angle of the photo.
THSIM9
Idaho
Pulled the rest of the interior, cleaned, and installed dynamat. Started working out more kinks with wiring. I’m going slow identifying every wire and where it goes, labeling accordingly, so that when it comes time I can make all my connections and get everything into wire loom and tucked away. It’s a slow process but it should pay dividends in simplicity and function now that I will know exactly what ever wire is doing.
I did that with my samurai when I converted it from carburated to obd2 efi, having neat wiring is just the best, plus easier to diag if something messes up
Looking good!
Lookin good. I Dyna matted my 85 extra cab, did back and side wall also.
Then got carried away and did the 86 also, plus inside the doors.
Looks like you totally covered the trans plate cover. Be a good idea to not
cover the screws, and the screw holes for the rubber boot. some day you
may need to remove the plate.
East Wood sells their brand of material a bit cheaper than Dyna Mat, and
probably the same exact stuff.
I saw another brand "B-Quiet. Just received a roll 12" sqft roll for $48 to check
the quality. Looks close to same thickness.
They have a sale going on now.
Just reread through your thread, you are going to have a nice truck when through.
There is some threads on changing the side quarter window with the divider, to
the later style of the 92 - 97 all one piece window.
If interested I`ll post what I have come across.
THSIM9
Idaho
Thanks Goat for the recommendations. I grabbed a roll of that B-quiet material to finish the cab, doors, etc. it’s quite a bit cheaper per SF than dynamat.
Post what you think about it.
I read on (maybe FTE Forum) guys using this stuff.
Has 1/8" foam on back side with stick um, and tin
foil on front. Bought a roll and used it on the back wall
and side walls of the extra cab over the top of the Dyna Mat.
Could use it on the floor also, but would use the Dyna mat
type stuff first, as the tar backing will make a water tight seal
when rolled in tight with the wood roller.
Was $19 before Covid.
Back when I used the Dyna Mat it was $160+ a box.
Searching found that Eat Wood had the same stuff, (their Brand) for $92.
Now it is $164...yikes....before Covid.
THSIM9
Idaho
After a couple weeks of not touching this project I was back in the shop this weekend.
The B-Quiet material was great. I would say it’s close enough to the dynamat to be a consideration.
Got the intake installed, some more wiring figured out, and the dash put back in the truck. I got the custom gauge cluster roughed in, just need to paint and mount gauges. Unfortunately the gauges ended up slightly off center but I’m going to live with it for now. I’ve gotta get this thing done and back on the road.
DaveBen
Ukiah, Ca
If you look at where the string column goes, they are not out of line.
