Will a 88 f350 dually wheel fit a 92 f250.
bumblebeer
ALABAMA
I had a blow out in the f250. I don't have a spare but I have an extra tire and wheel from an 88 f350 drw. Can someone confirm if they would be interchangeable for me to limp it home or to a shop?
bumblebeer
ALABAMA
Oh and it's one of the rear wheels. Figured that would be important to mention.
Rdnck84_03
Kansas
I believe the bolt pattern is the same. I have a dulley wheel on a f250 axle to move it around the yard. I think you will have to flip it like an outside dual. I think it will hit the spring turned in without the spacer.
James
bumblebeer
ALABAMA
James
Yep it fit turned to the outside. Now let's see if it'll ride! Gotta make it 11 miles.
bumblebeer
ALABAMA
It worked. Made it to the tire shop. Thank y'all! Guess I need to go and buy a spare so I won't be in that position again.
