vt365 question/help
corliss010492
mass
i have a international 4200 with a vt365. the truck will not start(unless sprayed with starting fluid and it will start and run fine) the most injection pressure i can get is 480psi. ive tried unplugging the icp and that does do anything, and it has a new ipr. can i high pressure oil leak cause this or is it most likely a hpop. i was am going to air test it just wanted some input. and also the truck does have one code for injector 4 circuit,i believe it is code 454. could this all be something with the computer causing this or could it be two separate problems. any input or help would be great. thanks
gavinc
