1993 f350 7 pin help.
derickknowsmows
Missouri
Hi, I’m trying to figure out how to install a 7 pin and 4 pin connector on my truck, however I’m seeing very confusing info during my research.
So my truck has a trailer brake controller wired into the plug under the dash.
I have read that there are two connectors under the bumper for the 7 pin, which I do have as capped off wires.
Another thing I read was that there are supposed to be some relays or stuff next to the fuse box in the engine compartment, I don’t see any of that on my truck though. And I also have this harness that comes out of the fuse box(8 wires in the plug), splits off to go to what looks like a sensor in my brake line right around the pig tail thing(2 wires go to that), and then goes under the truck along the frame rail, and cuts off with 4 dangling wires. At the start of the harness it has a tag that says ford p260g. What is that harness? And how can I install a 4 and 7 pin combo plug? And where does the brake controller go after the dash plug? Thanks.
Clb
Another old truck
nannyfornia
etrailer.com for schematics
the ford have pigtails under the rear bumper.
4 vs 7 pin is just a splice it in situation
note there are 2 color codes 1 is sae the other is traditional
verify your trailers setup first
placidoert
