Removing Fan Clutch when all accessories are removed
I have a 7.3 engine out of a 89 F250 which uses the V Belt setup.
There are no accessories IE, Alternator, AC Compressor, Vac Pump etc...
so no belts to help hold anything, it`s just free wheeling.
I have the Special Wrench to knock the big nut loose, .....
I been searching on Google to see what I can find, but the usual stuff is
the engine is in the vehicle and everything is still connected.
I found a couple YT Vids that are interesting.
What have you used on these IDI`s?
Is there some magic Fairy Dust I need?
This engine is sitting a tire on the shop floor.
Austin86250
idaho
when i removed my fan i went to napa and they rented me a tool for free that hold the pully in place
im sure other parts stores rent it too
gnathv
Athens, Al
The fans mounted on the water pump, stopping the piston would have no effect
TNBrett
Middle Tennessee
You can try and fashion a strap wrench from an old fan belt. Try feeding the belt through a box wrench. Use this to hold the pulley. For the fan clutch use a large crescent wrench, and hit it with a big hammer. This may require 3 or more hands to accomplish, and gloves may be called for to save some knuckles.
See that pulley bolt in the picture below? I made a piece of metal shaped in a y and on each end of the y I drilled a hole that would match up to two of those bolts. That holds it.
