please give me advice
cKicker
Tigard
1st problem: Im in the process of installing a push button GP switch and new relay. I cant hear the the click. Ive got power coming from the push button. The relay is getting very hot, but still no click. Whats the red and purple wires for? Do I need to connect one of those too? I must be missing a step somewheres. Next problem: I have a miss. Do I have to pull all the injectors and them tested?
Clb
Another old truck
nannyfornia
1 put truck specs in sig line ( helps us figure you out)
2 year ?
3 hit tech 101 stickies yet?
4 we don't have a lot of spoons available for spoonfeeding, but can send links sometimes.
Next helpful guys turn
greenskeeper
PA
What year truck?
The PCM grounds the relay when it wants to energize the glow plugs. So to make it "push button" you would need to wire the relay ground through the switch and then to ground.
What type of miss? At idle? Under load?
Clb
Another old truck
nannyfornia
Does it already have the gpr bypassed?
