Difference between rtoo 9513 11613 14613
Daniel McCurdy
Evarts KY
Does anyone know if one will make less noise and heat than the other. Is there a size difference between them. Do they all have a sae 2 bellhousing.
jaluhn83
Upper Marlboro, MD
The first part is rated input torque - 950, 1150, 1450 ft/lb, so size, weight and toughness likely scales accordingly. As long as you're running within rated specs I wouldn't think heat would be an issue for any. Noise is probably more a function of condition than specific model. No idea on bellhousings, you'd need to do some research.
Nanohawk
