c6 to t-19 questions
Where / how I was unable to get off as a whole?
Just unsnap the slave, disconnect any line clamps, and unbolt the clutch master off the firewall. Disconnect the pedal linkage under the dash and then go out under the hood and carefully pull the whole thing out.
I just did this on my little Bronco II, and it has the internal slave and a remote reservoir. What a pain guiding all that mess down from the firewall as I am pulling the trans back off the engine. It was really fun putting the trans with the clutch system back in. Pushing the tranny forward a little bit, guiding the remote reservoir and clutch master up, pushing the trans a little farther, and inching the whole thing forward till I finally got it in place.
But the clutch worked perfect the first time I tried it, no bleeding required.
I think I worded that a little off, I’m taking about the bolts that attach the t-19 to the bellhousing there’s 4 not the 6 that attach the bell housing to the block/ adapter plate
I hate those people who remove the bellhousing from the transmission. There's always something missing and half of the time it's the bellhousing itself.
Austin86250
idaho
Yea your right I never saw a t19 for sale with a bell housing…
Austin86250
idaho
I think it’s a 3/8 coarse thread I’ll I need to a grade to shoot for
Austin86250
idaho
for anybody else who needs this info the hole for the clutch master you need to drill is 1.5"
Austin86250
idaho
Everything that had to do with an auto is GONE! Didn’t make too bad of time either took me 4 hours for everything
Had to throw in the Manual plate tonight too
Your are making good time, you will like the gear box, I can get 20 mpg on a pretty steady basis....empty and 3:55 gears.
If you can find a gear Vendor, it will give you an OD, plus you can split the gears. I found one in PNP last OCT, like finding the needle in the hay stack. Haven`t seen one ever in PNP.
Where the tack is mounted..I don`t have one. I drilled a hole and mounted a Vacuum Gauge in it`s place.
Used some flat black and covered up The KM junk. makes it look very different covering up all the white stuff.
Austin86250
idaho
7/16 x 16 x 1.5” for t-19 to bell housing if anybody is wondering
Austin86250
idaho
Alright! I think I got the clutch bleed with that being said this may be a stupid question but what’s the full level is it the top of the skinny part?
