Bullnose tach cluster
Austin86250
idaho
Just scored a factory bullnose tach cluster today 90$
Been searching for over a year now could only find one for 200$+
I’ll be painting the needles,red line, and yellow line I’ve never seen anyone do it so I figured ittl make a fun little thread for any interested
Just jammed the tach in and it does not work right now unfortunately but the tach sensor I have I just ripped out of the junkyard so I’ll start with a new sensor
I found 2 one is a dorman from autozone, not a fan of dorman so I prefer not and
Genuine Ford Parts - Sensor Asy (E5TZ-17B384-A)​
This off Amazon I remember hearing fake motor-craft glowplugs so can anyone verify the legitimacy of this?
Timber-Reaper
Oregon
So I've done this once and my truck didn't have a tach factory but it had all the wires and it didn't work I has to wire the back I'll send a pic
Timber-Reaper
Oregon
I've also painted the needles but not the color in the tack I used an orange made by folk art it looked good but it was a few shades darker than factory. Nobody ever noticed or called me out but I knew and that alone drove me a little crazy lol I also had all leds in the cluster so it really looked cool at night
Austin86250
idaho
found a proper guide on changing the odometer reading.
and general info on tachs
Austin86250
idaho
Has to get creative and use toothpicks
Austin86250
idaho
The second oem parts I’ve ever bought hope it’s worth it
Austin86250
idaho
Finished painting her up! Hopefully I can find a better plastic but she’ll do for now
Now I just need to get the tach working everything has continuity on the dash side hopefully I found bad wiring under the hood somewhere
Great job Austin, looks good.
Now you only need one more thing...a 6 digit Speedometer.
I found 2 NOS OEM in the original packaging.
One is going in the 85 and other the 86.
Amazing what the gauge`s looked like when these trucks came from the Dealers, compared to 38yrs down the road.
The link to Gary`s Garage he shows how to reset the wheels. That same paper came with my Gauges. I have taken the Mercedes Spedo`s apart to clean and or reset the ODO for the car it is going in. (300D, 300Turbo Diesel, 240D, 280E)
Once you remove the shaft for the Cog`s, the # wheels can be turned to where you want them, then slide the Cogs in one ata time on the shaft, and secure it.
I`ll see how this Ford one works out....
I don`t have a Tach, and never seen one in the Junk Yard`s. So cut a hole and mounted a SW Vac Gauge. Now Iam thinking of swapping in a SW Volt Gauge and move the Vac Gauge maybe down where you have your GP Toggle. I have a Black Momentary Toggle where your Push Button is. Blends in and not noticeable.
Austin86250
idaho
never heard of a six digit outside of kilometers very interesting. i already used garys instructions to put the odo where i wanted it.
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
So, you used toothpicks as paint brush? Not sure I follow… don’t understand I guess
What kind of paint did you use?
I want to redo mine, but, paint my needles blue, like the newer Fords.
Austin86250
idaho
I used cut toothpicks for the really thin spacing on the yellow and red lines because tape was impractical,
Since I somehow got another tach cluster from a parts truck I got I did it again and didn’t use any tape for yellow and red
