'95 F250 7.3L shooting oil out exhaust?
420Bullnose
U.S.A.
I got a '95 7.3L shooting oil out the exhaust, How bad is it?
Hopefully just the Turbo seals.
Any help or advice would be greatly appreciated,
Thanks,
420Bullnose
lotzagoodstuff
Carmel, IN
Take a look at your turbo and see if you’ve got play in the wheel or signs of seal damage.
If that checks out it could be injector orings.
Good luck
greenskeeper
PA
Good luck
injector o-rings would make the engine consume engine oil by mixing it with fuel past the failed o-ring. A telltale sign is oily diesel fuel in the fuel filter housing and obvious decline in oil level in the crankcase.
Most likely it is failed turbo seals that are dumping the oil directly into the exhaust.
