2005+ D60 swap in 2wd?
u2slow
bilge rat
Coastal BC
Anyone done this swap? Links/threads?
Always read that the 2wd coil buckets work fine, but then most builds seem to have endless budgets and they buy all the 2005+ brackets or a whole rolling chassis. Not here... best I can possibly do is a '90ish f350 2wd frame.
BlindAmbition
SoCal
I'm working on this swap now. Had a 2005 2wd f250 that I pulled the rear axle and all of the brackets off of (radius arm, coil buckets, steering stab)
Got a 2006 D60 and the track bar bracket and track bar
2wd and 4wd could buckets are the same
I've got a rivet hammer and an 80 gallon compressor, will be knocking all the old hardware off this month or next and putting the 06 Dana 60 under my 86 2wd f250.
