2005+ D60 swap in 2wd?
u2slow
bilge rat
PNW
Anyone done this swap? Links/threads?
Always read that the 2wd coil buckets work fine, but then most builds seem to have endless budgets and they buy all the 2005+ brackets or a whole rolling chassis. Not here... best I can possibly do is a '90ish f350 2wd frame.
BlindAmbition
SoCal
I'm working on this swap now. Had a 2005 2wd f250 that I pulled the rear axle and all of the brackets off of (radius arm, coil buckets, steering stab)
Got a 2006 D60 and the track bar bracket and track bar
2wd and 4wd could buckets are the same
I've got a rivet hammer and an 80 gallon compressor, will be knocking all the old hardware off this month or next and putting the 06 Dana 60 under my 86 2wd f250.
720Diesel
